Woodmeister
Quite frustrated here. Have owned 1974 TR6 from new & enjoy doing my own maintenance. But presently have a hesitation (worse when engine hot & mostly occurs under acceleration) problem that I can't solve. Please help.
Had broken my ankle last Summer so couldn't drive the car for 6 months. When trying to use the car again the hesitation problem was there. So for the last several months have gone step by step doing the following with almost no relief.
1) Fuel System to Carburetors: Drained & cleaned fuel tank & purged fuel lines. Replaced fuel filter & fuel pump.
2) Carburetors: Rebuild carbs. Made sure float bowl fuel height is correct. Made sure damper oil is at proper level & pistons operate freely.
3) Ignition: Replaced spark plugs, spark plug wires, coil, & distributor (yes whole distributor unit including points, condenser, rotor, cap). Made sure timing & dwell are set correctly.
4) Vacuum: Made sure all vacuum hoses & connections are tight. Vacuum reads normal (as it has been for last 39 years).
Maybe the carbs are getting too hot & I need to install some type of heat shield (but I never had the problem in past years).
Please help. What am I forgetting?
