Adam Salnick
Hi, I know it is summer, but I have a question about the heater controls for my 1969 tr6. My question surrounds the distribution box control. It seems to have three positons, in, midway, and out. How is this supposed to work. Am I supposed to be able to get heat out of the eyeball vents? With the heater control pushed all the way in, I get a mild amount of heat out of them, barely enough to tell. When I open the scuttle vent, the air flow goes way up, but it cools down. When I am moving, I pretty much feel like it is blowing outside air + 5 degrees. If I close the eyeball vents, and move the control to the middle position, I get pretty good hot air onto the windsheild. If I pull the control all of the way out, the hot air dumps out the bottom of the heater box directly onto the tranny tunnel. The air hoses are hooked up correctly I believe (defroster on the bottom and eyeball vents on the top). I feel like I should be able to get heat out of these eyeball vents. Am I crazy?
Thanks,
Adam
Thanks,
Adam
