I've been the stud route with two different good vendors, and have gotten different studs from both. Several of the studs for the exhaust are headed right toward the head bolts, meaning that too long a stud won't fit. There is probably some standardization, back in England when they built them, so I just go to a good bolt shop and get several and use the ones that work. You want the blank space to be in no-man's-land and you definately don't want too much stud sticking out, you might not get your intake on. You definately won't get a header on! I had to round out the corner on two of my nuts (no, not those) and use a good star washer to get them to bite. Sucked everything down nice and snug, then checked with my Snap-On torque wrench (only Snap-On tool I own, maybe when I hit the lottery) to 25lbs. Took quite a bit more torque. Guess I will retorque after I run it a while.
Bill
