Glad to, Mark.
I run the car up to about 50MPH or so, and then make a fairly hard stop, just at the point of impending lock up. Then drive for two or three miles without applying the brakes to allow everything to cool, and do it again. I generally do it about 10 or 15 times total. This procedure allows the pads to "bed" themselves to the rotor surface, that is, allowing the pads to make full, flush, contact with the surface of the rotor, while also allowing any residual chemicals in the pads to boil off.
One component of brake squeal is the outgassing of the pads, which essentially allows gas bubbles to form between the pad and rotor, causing vibration of the pad, resulting in noise.
While this is not a cure all, as there may be other reasons for the noise, it eliminates a majority of brake squeal, while also maximizing the efficiency of the brakes.
I hope I've described it well enough.
When I had a chance to do this with an insrumented test vehicle, a marked increase in brake performance, and elimination of noise was noted.
The down side is that sometimes it is difficult to find a suitable section of deserted road to do it safely!
Jeff
