mgedit
Have the transmission, driveshaft, and differential out right now as I install j-type OD. Differential mounts look good on frame, but I'm thinking as a precaution that I should replace the rubber bushings in any case although they show minimal wear. My question is ... for general road use should I stick with rubber mounts, which have done well for 25 odd years, or switch over to poly bushings such as those sold by BPNW? Are there differences in the different poly bushings offered by different suppliers? Thanks Mike.
