MTribe
Hey guys,
I just finished rebuilding my TR6 engine and swapping in an HVDA W58 transmission. Believe it or not, the garage floor is now dry beneath the motor! It doesn't leak! The key was using Right Stuff--I actually sealed everything with Hylomar and Permatex first, it leaked, took everything apart and resealed with Right Stuff, no leaks.
Anyhow, now I'm motivated to fix the rear differential leak so I won't need any drip pans beneath the car.
<span style="font-weight: bold">Anyone have any advice about what to do to fix a rear differential leak?</span>
Is it as easy as replacing some seals, or is it prudent to just rebuild the whole thing? If so, how much work is that? Should I just pull the whole thing out and replace the diff mount bushings too while I'm at it?
Any thoughts on how much work the above options are, and what should be done, is appreciated.
