vettedog72
I need some help with a cam. I am looking at a cam on ebay but can't get a reference with the Crane web page. If somebody knows how agressive this cam is or is not I would like to hear any comments.
Triumph TR6 GT6 camshaft Virtually new cam
High lift performance cam. New, not a regrind. Was removed from a freshly rebuilt otherwise stock engine because it wouldn't idle. This cam will NOT work with stock compression, carbs, exhaust, etc.
Cam Specifications:
Valve setting Intake .018 Exhaust .020 HOT
Lift
Intake @ Cam 2895 @ Valve 414
Exhaust @ Cam 2895 @ Valve 414
All lifts are based on zero lash and theoretical rocker arm ratios
Rocker Arm Ratio 1.43
Cam Timing .018
Tappet Lift Opens Closes Advertised Duration
@ Intake 27º BTDC 57º ABDC 264º
@ Exhaust 67º BBDC 17º ATDC 264º
Cam Timing .50
Tappet Lift Opens Closes Max Lift Duration
@ Intake 6º BTDC 36º ABDC 105º ATDC 222º
@ Exhaust 46º BBDC (4º) ATDC 115º BTDC 222º
Crane Cams
Part # 00213
Grind# S-264-C
Cam Specifications:
Lift
Cam Timing .018
Cam Timing .50
Crane Cams
Part # 00213
Grind# S-264-C
