bluemiata90
I bought a TR6 last fall, the previous owner said the clutch slave cylinder had a leak, drove it home with shifting issues. Up on jack stands and removed and rebuilt slave cylinder. Installed it today, bleed it and the slave rod moves the clutch bar back about 3/4 of an inch <span style="text-decoration: underline">only.</span> The clutch feels like there is no pressure and the trans will not shift into gear. Is there a trick to bleeding the TR6 slave cylinder, should the clutch rod move the trans clutch bar <span style="text-decoration: underline">only</span> 3/4 of an inch. or should I be considering internal issues with the trans. I don't see any leaks and the master cylinder is holding fluid. I'm a little confused on this one. Did the TR6 have any regular issues with the throw-0ut bearing or locking pins. I'm truly hoping it's not an internal trans issue. Any suggestions will be greatly appreciated.
Hi Guest!
