TR6oldtimer
Well, I am have real problems getting my rebuilt carbs adjusted. The are running very lean. The needles are out as far as they can go. I suspect I have a vacuum leak or source of additional air entering the system. For example, I can block the hose to the valve cover and RPMS go up significantly.
All the connections to the carbon canister are blocked, so I suspect that the new by-pass valves are the culprit.
When I replaced the diaphragm, I did not adjust the valve setting. So what I plan to do later today, is force the valves closed by turning in the adjustment screw.
Any thoughts or warnings?
