Hello again,
Eventhough my car is running, it is not running as I would like. I am basically a novice, and am trying to learn how to work on this car myself. Currently, I can not get the car to idle below 1500rpm. If I set it below this, it gradually looes rpms and dies. The carbs are kind of sticky. As a result, I have to pull out the choke in town some times. It also tends to skip occasionally when I go up hills. I am considering rebuilding the carbs. My first question is how do you know if the carbs need rebuilding? What is a good source for parts (I have not been impressed by the big three with carb parts)? Am I over my head in attempting this? I am also not clear on how to tune the carbs, or if I have done it correctly. I have an extra set of carbs, so at least I have the luxury of driving while I do this. Does anyone have any suggestions? Any help would be much appreciated.
Kevin
Kevin
