TR6 TR6 Cam Grinds
K
KSIS
Anyone know the difference between the early and late model cam grinds for TR6? looks like I need a new cam as number four lobe is wiped out in my spare motor.
The block is a late 76.
Yes,I just explored this. Beginning in 73 the stock TR6 cam was changed to a slightly more agressive stock cam. It is the same cam that was found in the later Fuel Injection engines, sometimes referred to as the 125 HP cam/engine.
Here you can see the difference in the grind.
https://www.hottr6.com/triumph/tr6cams.html
Odd,
If that is true, the more aggressive cam is cheaper with the big three.
If the later cams are more aggressive they are cheaper in price from the top three.
