bobh
Hi,
I recently completed an major upgrade to the brakes on my TR6. The master cylinder was beginning to leak slightly around the input rod. These are the things I did
1) Had the MC sleeved and rebuilt
2) Stripped and painted the vacuum booster
3) Installed the 7/8 wheel cylinders on the rear
4) Installed the 4 piston Toyota calipers on the front
5) Relaced all hoses with stainless braided hoses
6) installed finned aluminum drums on the rear.
7) Filled the MC with Dot 5, Silicone brake fluid
8) Bled the entire system. After all air bubbles were gone
We pumped 2 more times per corner to ensure no air remained.
9) Adjusted the rear brakes
When I test drove the car the pedal would first go nearly to the floor. When I release the pedal and pump a second time the pedal firms up and everything works fine.
I have not bled the system after the test drive
With all new hydraulics I didn't expect anything other than a firm pedal.
The rear brakes seem to be working fine. In fact almost too well. I painted the aluminum drums with silver Hi Temp caliper paint to keep the aluminum from oxidising and make them easier to clean. On the initial test drive while bedding the front pads the heat generated by the rear drums caused the paint on the drums to discolor. They are now the color of a lightly toasted marshmellow.
Does anyone have any ideas why the pedal is not instantly firm?
Considering the rear brakes appear to be functioning fine. I'm wondering about the front calipers/pads. I'm thinking of removing the springs that push the pads /cylinders back into the calipers, or having some shims laser cut to position the pads closer to the rotor.
Thanks,
BOBH
Thanks,
BOBH
Hi Guest!
