Thanks for the input guys. I just picked this car up 2 months ago, haven't driven it much yet, so at this point am feeling it out. It's had a full body and interior resto but not a whole lot of mechanical work. The PO wasn't a wrench twister so relied on small garages in NH and just paid. It was obvious to me, because darn near every body panel is new and the crankshaft pulley is heavily rusted and painted, that this car at one time had just sat. The PO tells me he has owned and driven it for the past 4-5 years. The flex hoses look like they were replaced about 5 years ago and look good. The brakes feel great and in my mind even if the hoses were deteriorated inside it would hold a pressure between the hose and the caliper, not the master cylinder. I can't get it out of my mind tho that the brake pedal was rock solid. I can't swear that it retracted to the rest position when I took my foot off it but am reasonably sure. At this point I'm hoping short rides locally can reproduce the problem and I'll have enough tools and thoughts with me to nail it down. I don't have a clue if there's anything in the brake booster that could cause this. I have read Buckeyes excellent brake info but need to do it again when awake and alert. I'm a night time web junkie basically. I've had a Spitfire for a number of years. This is my first TR6 and I'm finding this is a completely different animal. Couple of questions for your well experienced minds. If the master cylinder primary piston for some reason stuck in the bore, wouldn't the brake pedal and booster retract when I took my foot off the pedal? And from parts and book illustrations I get the impression that the tipping valve is mechanically opened by the primary piston retracting. Correct? By the way, is the tipping valve included in o/h kits? I've been a manufacturers service rep on equipment for 25+ years and it's just my habit to analyze the problem and nail it not replace parts til it's corrected. Besides, I've blown my toy $$ for now and don't care to spend half the season waiting for delivery of one part after another. I've thought of a stuck piston but I believe it was both front brakes as the discs were hot after 2 miles and only braking a few times. Also the fact that when I took my foot off the brake pedal asny pressure in the lines should have been released, which it wasn't. If it definitely comes down to the master cylinder, I'm not at all shy about overhauling it if an inspection shows it's a good candidate. By the way, Kai Radicke indicated only a month ago I think on 6Pack digest, that his company Wishbone Classics has about 20 masters in stock.
Thanks, Steve
[ 04-21-2004: Message edited by: machinemd ]</p>
