The switch is attached to the brake pedal and depending how you bend the mounting bracket it can be on a hair trigger.
The clutch pedal and brake pedal are mounted on the same shaft and sounds like this one is activating in sympathy with the clutch pedal movement.
I like the idea of keeping the tailgater SUV's at bay with this arrangement, might adjust mine for the same effect!
