Finally got some time for the tr and put it up on stands to inspect suspension. Ordered new polyurethane kit for front (to be done over winter) and rear shock link bushings (rubber) as the existing are pretty badly cracked. My questions are should i raise the trailing arm before attempting to change the bushings and is there a preferred position for checking the shock oil?
Thanks
JD
Thanks
JD
