TR4/4A TR4A Stainless Door Trim Question
Stinger
We're getting ready to install the stainless door trim on our TR4A and it looks like the end trim hole towards the back of the door is larger. Is there a special clip that is used on this end? If so does anyone know where we can get this part? Thanks
Can't tell you where to get one, but yes, the last clip is different, it matches the inside profile of the trim (which is starting to narrow there), rather than just being a round snap.
You probably could get away with out having that clip there, that trim is pretty rigid, and not all that much more is hanging loose without it.
Moss does list a part for the last clip.
The only part from Moss we can find is(326-525 $0.25
Barrel Clip, rear of door moulding) but this only seems to be the clip that holds the moulding from the inside. Is there another number for the post that mounts on the trim? Thanks
The post is welded to the trim,if you don't have the post you could make one and use a strong adhesive or do without. I went years without that last post on my 4A as long as you take care washing and waxing so you don't bend the end of the trim.
