All,
I am in the process of disassembling my frame and suspension / brakes. The rear springs are mounted differently left-right. I thought there should be a shim on the passenger side, but I found no such shim. The top of the leaf spring has a fairly large "box", for lack of a better term, and I have read on BCF that "The heavy duty/competition rear springs for TR4 did not use a spacer on either side. AFAIK the later leaf springs with a lot more arch and very large aluminum spacers didn't use them either." https://www.britishcarforum.com/bcf/showthread.php?20767-Early-TR4-Rear-Leaf-Springs
However, the different mounting can be seen in the photos below. Passenger side rear link is "down", driver side is "up". Is this correct?? Is this a substitute for the shim?
Note, I have a solid axle TR4A with an IRS frame. I've been told this is not unusual - but cannot verify if someone was trying to make me feel good or if I have an orphan car
Hi Guest!
