RJS
TR4A IRS Replacement Axle Shafts
Hi
I spent about 2 hours under the rear of my TR4A this afternoon trying to diagnose a clunk in the rear end. The clunk occurs when pulling away in first gear. I was able to rule out differential and differential mounting brackets (both were rebuilt about 4.5K miles ago). As best I can tell, without removing the axle shafts for close inspection, it is both u-joints in the axle shafts and worn sliding splines in the axle shafts. Soooo, I am at that decision point about the best course of action for repair. I prefer not to spend any more than necessary but, this car is a long term keeper and I want it to work at peak condition. My driving consists of easy-to-spirited weekend drives. My options appear to include in order of cost (low to high):
The first 3 do not include the cost of (4) new u-joints, etc. The last two, while much more expensive, due away with the problematic sliding splines and offers a significantly upgraded and stronger hub assembly. I figure the hub assemblies alone are worth $700 for the pair.
Any first hand knowledge or thoughts on the above options? I prefer to do a job once and do it right the first time. This is not something I want to revisit again for many thousands of miles.
Thanks
Bob
Hi
- Stock replacement axle shafts for about $200 a pair
- Improved modern type axle shafts with grease zerks from $260 to $320 a pair
- Uprated axle shafts for higher HP for about $880 pair
- CV Joint Axle/Hub Assembly for about $1,500 a pair
- Heavy Duty U-Joint Axle/Hub Assembly for about $1,650 a pair (honestly I would go for the CV joint axles before these)
Thanks
Bob
Hi Guest!
