TR4/4A TR4A rear brake lines
T
t tink
I'm trying to replace the rear brake lines to the hoses. I can't get the line loose going to the right side. I can't fit a wrench on the line nut at the junction. Maybe I'm not going at it from the correct angle. Trying to reach it from the wheel well. Is there a special wrench? hope someone can help. Thanks in advance.
Are you replacing the entire steel brake line, and is the junction you’re talking about for a solid axle, or is it IRS? And your problem is that there is zero clearance for a wrench, or is it just that the wrench won’t budge? Is there a component interfering—like the differential or the axel tube?
