Making progress - I'm fitting the grille back on. The bottom fastens to the top of the front valence through two loops attached to the back of the grille. Should there be spacers between the grille and the body? I'm asking because the grille seems to sit back about 1/4" or so from the front of the valence, without spacers. It will flex enough to pull back against the valence but I don't think I want to pull it into tension.
