I took my car for a great ride. Drove perfectly.
Thirty minutes later the car wouldn't start. I cranked it almost to a worn down battery. It seemed to me that upon disconnecting the fuel lead to the carbs, the flow was awfully weak.
Pumping the primer manually showed only weak spurts. Nothing I could do helped.
The sensation was like a dry crank, either no fuel or no spark. I fiddled with the coil wires, readjusted the points, and nothing improved.
But then, suddenly, it started up. Now that it's home, it won't start again. Same thing. Dry cranks.
What do I check first? That pump is only a year old, and if it's bad, that will be 3 bad ones in five years.
The coil I have no idea about. Do I pull a plug wire and hold a screwdriver 1/4 inch away looking for a spark? What should I do next?
Thanks all.
Thanks all.
