Captains_Call
Hi all . . . a couple of questions regarding a potential TR4A purchase. The car had a frame off restoration about 7-8 yrs ago. This would be my first British car purchase, so I'm a little cautious.
1. When I opened both the driver and passenger doors, there was a metallic "pop" sound about mid-way through opening the door. I was told it is a metal spring that holds the door open. Is this correct? Just want to make sure this is not symptomatic of structural issue. I believe the "pop" occurred when we both opened and closed the door.
2. I had a vehicle inspection done on the car by a British car shop. They noted a pop coming from the passenger rear area of the car during a road test. He said it occurred occasionally when driving over uneven pavement. They didn't think it was related to the suspension (they could not recreate the sound in the shop). They suspect it could be a body mount and the sound was caused by flexing of the body, but no way to tell.
3. No signs of rust underneath, but the drain holes in the rocker panels are occluded along the LH side of the car. Apparently the panels were not aligned just right during the restoration. There were some indications that plates (4X) had been welded to the frame b/w the control arm mounts during the restoration. Panel gaps were OK. I was told that it had been a competent but not top end restoration.
Any thoughts/comments are appreciated. The car shop gave it a generally good bill of health and stated that it would cost 2X the asking price (asking = $26K) to bring an average TR4 to the same level of cosmetic/mechanical restoration.
Thanks!!
Thanks!!
