TR4/4A TR4A Dash...was the wood veneer stained?
karls59tr
Bronze
Have to refinish mine and was wondering if the original wood veneer,for a stock finish, was stained a a light blond or maple colour or was the wood just varnished(shellaced?) with a clear coat? What type of wood veneer was normally used back in the day? Satin or gloss? Thank in advance Karl
Triumph advertised the 4A's dash as walnut. The varnished finish was gloss.
I don't think they were stained. My first TR, a 1967 - TR4A, had an English Walnut (veneer) facia. As the finish aged the varnish became brittle and cracked. I carefully removed all of the old varnish (it wasn't transparent - sort of looked like orange shellac). The resulting exposed veneer was fairly light for walnut, so if a stain was used it must have been neutral, perhaps for sealing purposes only. We refinished the facia with a Danish oil treatment which resulted in a deep satin finish - beautiful. This was my preference. But, if I had used a high-gloss exterior polyurethane varnish,I believe it would have looked very original. Alas - no photos survive.
I obtained a used one, lightly sanded it back to the veneer and then used Tung Oil on it. That way, if it needs to be touched up, it's an easy job and not a complete refinish again.
Hi Tom So the middle picture is after the dash was stripped and the Tung oil applied? Nice look...it seems darker or is it just in a different light?....is the last pic before the stripping? Ian: does the Tung oil darken the veneer or does it look much like it did when stock?
Having seen many different TR dash's now, I wouldn't know what is stock any more. I couldn't find a before shot, but I remember that the original finish was quite bad. I would think that it has to darken it a bit, which I know isn't much help. I was looking for something not too dark or too light.
Here's mine, for what its worth.
An option is to go upmarket with the timber dash for a really swish look.
When rebuilding the TR5 I had the dash veneered in burr walnut. It was one piece of veneer split with a central vertical join, so the grain mirror imaged side to side. Multi coated with anti UV lacquer, and the finished result was as good as a Roller or Bentley.
Four years later that car achieved a then record TR5 sale price of $60K.
Viv.
I chipped the veneer off my TR250 dash, then just lightly cleaned and sanded and finished with clear polyurethane. It did not appear to have been stained or if stained it was a light stain, bur the clear finish made it look quite a bit darker than original and even darker than the earlier TR4A dash, but I like it, don't have any pics, but it is quite a dark, rich look.
The first is before stripping it, the second is after the finish was applied. It was the bright sun. The third was after it was back in the car. The camera and sun brightness and angles effected the photos. I used Birchwood Casey products on it. https://www.birchwoodcasey.com/
On my GT6 I used a light colored walnut and rubbed it with Danish oil (and rubbed, and rubbed, and rubbed . . .).
Looked perfect. The original finish on MKII GT6s was not varnished, but a silky fininsh. Quite natural looking, I like.
Nothing beats a nice wooden dash, IMO. I marvel at some of the upscale Brit cars of the day: Bentley; Rolls, older Jags. Pure beauty. I could sit and just stare at the woodwork for hours. :crazyeyes:
