Darrell_Walker
Someone (probably Randall) mentioned that the TR4A dropped the return spring on the clutch slave cylinder that the previous TRs had. A while back I added a return spring, thinking it (like many parts) was just missing.
So I'm planning to remove the spring, but I can't find in the shop manual any adjustment instructions specific to the TR4A. So what is the procedure to adjust the slave? As I understand it, the spring in the slave is supposed to keep a little pressure to keep the throwout bearing agains the pressure plate?
