Hi all,
65'TR4A here. Oil PSI ~ 50 psi then drops to 25-35 range when engine heats up. when hot and at idle gauge shows ~10 psi. Driving in south Florida so it is quite warm. Water temp stays in the normal range. Was considering adding an oil cooler to improve oil temp and possibly psi. Has anyone tried this in hotter climates and did it work??
Thanks,
Jim
Thanks,
Jim
Hi Guest!
