The driver and his lovely are down 25lbs from last fall. During the overhaul completed last spring 2018: The Dunlop 195/65-15 on 6" VTO wheels were replaced with Vredestein Sprint Classics 185/70-15 on 5.5" Panasports, 32lb. The stock radiator was replaced with an aluminum one, 13lb. The stock flywheel was replaced with a lightweight steel model, 19lbs. This week I will replace the stock battery with a Miata type, 16lb. All up about 105 lbs. I didn't count replacing the stock rods with Carrillos during the engine rebuild/heatup, probably a few pounds there (that were a joke).
