TR4/4A TR4 sway bar dimensions
tdskip
Hi guys - can someone check on TR4 sway bar dimensions.
The seller measured the bar he has and reported back that the bar measured
25.5" from the middle of one bend to the middle of the other.
The links are 8.25" from fork to tip of ball. Overall width of the bar at
the widest is 36.5". It is 2.875" from end of the ball stud to top of
ball. Diameter of the bar is 9/16".
I know/believe that the diameter is correct, can anyone comment on the other measurements?
Thanks,
Tom
Found one in a (large) box of parts - represented as for a TR4 but trying to make sure.
Seller is a good guy, but it was removed from the car a long time ago....
Bend to Bend is about 25.5"
Mid Hole to Mid Hole is about 34.5"
Depth is about 10"
Myles
