TR4/4A TR4 Suspension
mylesw
Hello
I'm currently restoring a 64 TR4 which has the deep dish springs at the rear and the blocks between the spring and the rear axle. I'm wanting to uprate and lower the suspension and I am therefore considering changing over the rear to the early lowered spring by purchasing a new set of plates, u-bolts etc as per the earlier TR4. Has anyone on the forum done this before? Are there any pitfalls? Does anyone know where I can buy these springs in the US (apart from Moss who are currently out of stock)?
Another quick question - the powder coaters have powder coating the bearing surface on the front suspension pins on the frame. Does anyone know the best way to remove powder coat without damaging the underlying bearing surface?
Thanks for your help.
Myles
Myles,
I'm reasonably certain the ride height remained the same with the later spring design (which was supposed to improve handling). If you really want to lower it, I'd suggest just adding some spacers rather than replacing with the early setup.
At least on the TR3, those pins are supposed to be removable, so you can change the springs without removing the body. If I were doing a frame-off, I'd want to remove the pins and coat them with anti-seize where they go through the frame.
It's not really a "bearing" surface, the bushing in the spring eye has a steel sleeve that gets clamped tightly so it doesn't turn. The rubber flexes with suspension movement. I'd just clean the pin up with crocus cloth until the sleeve will slide over it.
