TR4/4A TR4 shifter and transmission tunnel
F1LOCO
Ok, so I got a proper TR4 shifter for my TR4. PO apparently did the TR3 conversion which I can't stand b/c I keep hitting my knuckles into the dash pod. Question, am I able to take out a seat, pull the carpet and access the tunnel for removal and swap, or do I have to take out both seats/carpets to accomplish? Like to keep work to a minimum and no surprises on time...
I'd recommend pulling both seats, your going to be up inside the car taking out bolts the secure the trans tunnel to the body. You are going to want all the room you can get. The trans tunnel when it comes out will be like removing a puzzle piece. Again you will want the room to wiggle it around to get it by the emergency brake and over the shifter. Not a hard job, a couple of things to work with but plan on a 3/4 hours for the job.
BTW - reread your post, you might be lucky enough to do this w/o removing the sests. Remove the rubber boot around the shifter (with the trans in neutral) then remove long bolt that goes thru it ( that will be the key), pull the metal ring, that may require a little tapping with screwdriver & hammer to move it. Once its off the rest will go quickly.
Marv
Marv
Thanks, I'll give that a try b/f I get crazy....
May be too simple but why not just unscrew the shifter and take it to a machine / job shop and ask them to shorten an inch or so and cut new threads.
Lou Metelko
Auburn, Indiana
Lou Metelko
Auburn, Indiana
Actually, he has the "short" TR3 shifter on there now, and wants the longer TR4 shifter. The big difference, is that the TR4 shifter has a bend in it angling it back. The straight TR3 shifter he has causes his hand to hit the dash.
Besides, the shifter doesn't just unscrew. The knob does, but not the shifter arm that the OP wants to change.
