Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
So, I was cleaning it and noticed the silver trim on the top of the rear fender is coming loose? Is there fix? How is it attached?? Couldn't see anything but space?
If you look up inside the wing you should see sheet metal tabs that come down thru the seam and then fold over, securing the bead.
It will be close quarters back up there but you may need to straighten & tug on that tab (also pressing on the beading with your third hand) before bending it over once again in a tighter position.
It's also possible that the tab is broken or missing, so step one is to peer in there and see what's what.
Here's a pic inside there, you can see the tabs sticking down and (crudely) bent over:
