Can the "zero" clearance problem between the fan extension hub and the steering rack be cured with thicker, better, new motor mounts?
It would make servicing the engine easier, as well as changing fan belts. Alternatively, I could add spacer below the existing ones.
What about the stuff on the outside of the timing cover. The stock cover had a sound deadener sprayed onto it. Isn't there a product on the market that would double for that? It may be a nice touch.
thx
thx
