TR4/4A TR4 headlamp switch
Kirk_Fisher
Neither Moss nor Victoria British are showing a switch available in their catalog. I called both and the "operator" was zero help and there is no tech support. I googled the part and I am only finding dimmer switches. Any idea where I can obtain one? TR6 switches are available.
I made a high-speed run on a local mountain the other night and as I was setting up for a sharp left hander, the headlights went out. I have a nice video of it...;)
Hi Kirk,
We usually have the headlamp switches but there is an issue with them right now.
You can find it here under part# 48 https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29194
It seems the batch we received will not stay in the first position and returns to off. If you pull to the second position, then back to the first position it stays.
Hopefully I looked up the right thing.
Shawn
PM sent, but also...
You might want to check your grounds unless you have a definite reason for believing the switch has failed.
