I'm getting ready to put my oil pan back on. It was leaking badly.
Something just isn't right. The entire gasket was soaked with oil and the bolt holes really aren't terribly distorted. The oil soaking included the elongated troughs between the bolt holes.
I'll work with the holes a bit, but the front sealing block was also quite wet with oil.
I assume I can remove that and replace the felt side seals with something I can make? Any advice there, and could this help with my problem?
Since the entire gasket was oil soaked, literally all of the surface (and, by the way, all of the bolt heads were showing oil before I removed them), I'm assuming that oil my have infiltrated from the front and worked its way back.
I realize I may be reaching, but I'd like to think that I won't be pulling the pan again soon.
Thanks in advance!
Thanks in advance!
