[ QUOTE ]
Alan,
Where did you source your competition springs? Do you know what rate they are?
Thanks,
Greg
[/ QUOTE ]
Hi again Greg,
Sorry, I don't recall exactly where I got the heavy duty rear springs. They were purchased 5 or 6 years ago, I think. They came from one or the other of the major U.S. vendors, I'm sure (Moss, VB or TRF). They are Triumph part #304008 for TR4 and the distance pieces aren't used with them.
The "competition" spring rate is 155 (+/- 5%) lb/in. (Compare to 128 lb/in for both types of stock springs, which are part #208636 up to car CT23382 w/o the distance piece, and part #209964 for CT23383 and later with distance piece.)
I find the rear ride height a bit high with the competition leaf springs by themselves, but it's pretty easily adjusted by putting spacers between the axle and the spring, which also requires specially sized u-bolts. Custom made aluminum spacers or distance pieces (probably somewhere between 1 and 2" thick) can be used to set the ride height just about anywhere that works best for any particular car setup. I've looked for but havent found any useful adjustable wedge type spacers. Most are too wide (made for bigger 'Merican cars with wider leaf springs).
Let me correct something. In my first response I wrote that I thought Triumph added the distance pieces and recambered the spring to help reduce "bump steer". I think Mark is more accurate in his response that they were installed to try to correct "roll steer", which is a bit different. (Of course, the 20% stiffer springs I'm using will also reduce roll steer, without the distance piece, although the ride might chatter my teeth a bit more.)
At some future time I'd like to fiddle some more with the rear springs & shocks and see what can be accomplished. I'd like to try a monoleaf spring combined with an uprated shock (possibly tube shocks, or larger/adjustable lever shocks). There are various other options, too, such as slightly tapered shim plates to correct for spring twist, roller-type rear hangers, adding a panhard rod, etc. But, frankly and realistically, IMHO all this is aimed at getting the last 2 or 3% out of a primitive suspension that's already suprisingly effective on these cars, in terms of handling if not ride comfort.
