Well, I'm settled in the new house and found all my tools, so it is time to get back to tackling my non-alternating alternator. As a quick recap, with help from this group, I have tracked down my non-charging problems to the alternator conversion the PO did. After finally getting it through my thick skull how an alternator works, I think I've got too loose of a belt. The alternator top mount uses the old generator bracket, slightly cut down. It mounts the alternator way out by the wheel well (almost touches). There is no way to move it closer, since the arc of the bracket is not the same as the arc of the alternator.
The PO used the pulley from the generator, and put on one of those temporary belts (red, with links). I'm sure it slips some, and it is quite loose. From my reading, it would seem that an alternator needs a much tighter belt setup than a generator, so this might be my problem.
The simple solution would seem to be to modify the bracket to give a wider range of adjustment, and get a real belt. Thoughts? What have have folks done for that top bracket? With that generator pulley, can I use a standard TR4 belt?
