BobWaldeck
I need some advice from those in the know. I am restoring a TR3B, and will be needing wheels/tires soon. I am looking at the Rewind style mag wheel or a Konig Wheel, and am trying to determine the largest wheel that will fit without rubbing. I would like to go with a 205/60R16 since the diameter is nearly identical to the original Bias Ply tires. The concern is the tire width, this is a much wider tire, and some of the rims I am looking at are only available in 7" widths. I test fit such a wheel on the car while on the lift (engine not installed), and no issues with the suspension extended. I am concerned about how things will work with weight on the suspension. Is there anyone out there running similar large wheels on a TR3?
