I should also mention that with respect to the rubber on the bottom of the windscreen that goes against the car, be sure that when you insert it to the metal at the bottom of the windscreen that you have the lip curl back toward the inside of the windscreen (ie., curling toward the back of the car). I know it may not seem right now, but once you put the completed windscreen on the car, it will make sense. That is, the pressure on the seal when you pull it forward to put it on the car will make a complete seal. Do it the other way, and there may be gaps.
Re some of the earlier questions, yes, I wrapped the rubber seal/glazing around the glass - kind of like a "U" shape - and then trimmed it with a razor blade. I did not use glue.
I really did not want to do this project, but considering that I spent so much time and effort on the rest of the car to make it look good, I thought it was a big compromise not to do it. Also, I dont know how other feel about this, but Ive found that the best time for me to do this kind of difficult (or mind numbing) stuff is while I am still knee deep and interested in the overall project. If I leave it until later, it probaly wont get done as Ill lose interest and have moved onto someting else. In the meantime, it will bug the heck out of me that its not done and that I didnt do it when I could have.
