Hi Guest!
Tinkerman said:I'm sitting here looking at it and it seems to be a fairly long line. Any particular routing requirements?
Thanks, Tinkerman
I believe the port should be on top of the front carb, centered over the bore and up against the flange that bolts to the manifold. At least that is where it is on my Stag.maddabe said:I've got Strombergs on TS18057L and I've never had the advance hooked up. I just plugged the port on the distributor. Where the heck does the line go on this carb setup?
I have a short section of rubber line there, for much the same reason. Also makes it easier to hook up a Mity-Vac, to test the advance.Moseso said:Note the loop for strain relief,
