Hello all, I have just finished rebuilding my Tr3 engine and am attempting to prime the oil system. I made a spade tip rod and chucked it up into a drill. spinning it counterclockwise ate about 750rpm i get oil to the block galleys and through the pressure tube. but no oil is appearing at the top of the head! none at all through the rocker pedestal hole and none at the back aux oil in hole. the block has been cooked during the rebuild. could i have put the head gasket on upside down? It is the steel shim type. what could be causing the lack of oil? Also is there any way to probe the pedestal hole?
thank You
thank You
