My post TS 60000 TR3A (non Overdrive) has a new speedo cable from VB.
The inner cable square end is 3/4" long protruding from the outer aluminum fitting. This is at the the trans. end.
Problem is, my trans sq. hole is only 5/16" deep.
I assume I can cut off about 1/2" with a dremmel tool, hpefully without unwinding the strands.
This does not seem like a lot of engagement but I hope it will work.
The cable fits fine at the speedo end with good engagement & no binding.
Anyone else have a problem of this nature & how did they fix it???
Thanks,
Bob
Thanks,
Bob
