BritCars54
Member
After several days of trying to troubleshoot the horns on my 60 TR3A, I fortunately had to return to work today, giving me a week before I can approach the problem again, also allowing time for the Lucas-induced fugue state to fade. I have tested both horns (brief direct connect to the battery) and they appear to have the ability to function. I found all the appropriate wires on the wiring diagram.
The fuse is intact. With a testing light, the horn switch appears to work. I cleaned up all connections. I have the Green Brown to each horn, Brown Black to passenger horn, which combines with another Brown Black that crosses over to the driver side. This then combines with the Brown Black from the horn switch that comes out of the bottom of the steering column, and these connect to the driver's side horn. No response. I did also found a Brown Black wire coming out of the drivers side harness, but the wiring diagram does not show such a wire.
Any suggestions?
Thank you.
Any suggestions?
Thank you.
Hi Guest!
