Does anyone can tell me where the Engine ground strap is located ona TR3A. Also, This part does'nt seem to be available anymore. Any acceptable replacement available?
Goes at the LH motor mount, close to the dipstick. Upper end on one of the bolts that holds the timing cover to the engine front plate. Lower end on the bolt that holds the motor mount to the frame.
TRF has a replacement listed under LUCMB114. Moss 736-040 would probably work too.
This photo may have come from Don Elliott originally, but I neglected to make a note of it.
