I believe by 59, the horn fuse had dropped to 35 amps, meaning both fuses in the fuse block were 35 amps, while the in-line holder under the dash (if present) was 25 amps. Earlier cars had a 50 amp fuse for the horns.
Note : <span style="font-weight: bold">these ratings are in the obsolete Lucas/BS fuse rating system!</span>
They are roughly twice the rating of a comparable American standard fuse.
IOW, an AGC 20 is a suitable substitute for the specified 35 amp, while an AGC 25 may be used in place of the 50 amp. This is particularly important to know if you are on the road and need a replacement fuse.
'Correct' Lucas-equivalent fuses (which are also slightly smaller physically than the AGC fuses) are available from the usual suspects.
