Wanted TR3A competition springs (lowering)
newmexTR3
Hi- upgrading my front suspension and looking for a set of uprated, lower front springs.
thx!
Hi
Check out the revington site in the uk
Not saying you have to buy from there but it gives an idea as to the cross over parts
note some front springs are longer than the std TR3 springs but you use them without the aluminium spacers
Some are shorter springs but for the rear of an irs (4a to 6 model) that work with the Ali spacer.
you can lower the car by turning over the bottom wishbone arms.
may I question what you are trying to achieve as there may be others solutions.
Eg I use these on the front with the Ali spacer and the thicker poly spring seats
It’s a little higher than normal but I have other modifications too.
Hey, thanks for the tips. I had actually been talking with Revington about different options, but this is helpful. Checked out your YouTube vids- lovely TR! What size steering wheel are you using? I think I'm finally at the point that I want to go with a smaller wheel than the stock- would make getting in and out of car with my Corbeau seats much easier.
Thx. I converted to R&P a while ago, it makes a world of difference. The only downside is that the turning radius has now become that of the QE2, lol. Other than that, the steering is amazingly light.
