One last shot before I take it to a professional.
After having the clutch master cylinder sleeved and rebuilt and installing a new slave cylinder kit and bleeding the system numerous times I still can't get it working right. Here's what i have observed.
Initially no pedal resistance.
Pump the pedal 2 or 3 times and I get normal resistance and normal shifting.
Take my foot off the pedal and it loses complete resistance in a few seconds, but if I keep slight pressure on the pedal (at top end) it maintains normal resistance.
I have also noticed that when I depress the pedal, even when there is no resistance, the slave cylinder pushrod extends?? but probably not the full distance since it won't shift gears.
Any thoughts, ideas, tips, hints etc. will be greatly appreciated. TIA
Hi Guest!
