Uh, Don, I think if you'll check, those were 11" rotors. But I agree about the .500" part (making minimum acceptable about .440"; although I have seen people run them much thinner with no apparent problems).
At least some of the later 10-3/4" rotors are stamped .440 minimum; and new ones also measure very close to .500".
BTW, the new rotors I got from Rimmers a few years back (at a show) have some significant balance issues. If you are replacing rotors, you might want to check the balance afterwards, as well as the runout.
Are your old rotors scored or something? While common practice these days is to resurface them at every pad change, it seems like a waste of very expensive metal to me.
