I have a definite intermittent squeak from the right front. Intermittent as the wheel turns. Am sure its the brake because it goes away when slight brake pressure is applied. From reading past posts it would seem the rotor is warped and rubbing against the puck as the wheel turns. The solution to this would be either have the rotor turned or replaced. If I replace the rotor, should I replace both or just the one causing the squeak? Have no idea the age or thickness of either rotor at this time.
