I had rebuilt both master cylinders last year, and ever since the brake pedal has a lot of movement while the clutch seems to work fine. The pedal will "pump up" a little bit (ie. has some air in the line), but not much. I did re-build the calipers and replaced all three rubber lines. There is no loss of fluid at all.
Is it likely that my rebuild of the brake master cylinder has a problem? Or is there another cause? The pedal goes almost all the way to the floor. Car stops just fine.
