Hi Capt Roy,
No, you don't have to give up your amp gauge. You do need to convert your car to negative ground, which simply means reversing the connections at the battery (when it comes time to hook it bakc up) and on the amp gauge and at the coil. Unless you have a positive ground radio installed, everything else should work fine and your headlights will actually be bright enough to drive at night! /ubbthreads/images/graemlins/driving.gif
Here's a website that shows installation on a TR3
https://triumph.daveola.com/Album/Alternator_Conversion/
He also describes a kit he bought and where he got it (I have no personal knowledge of that vendor).
If you are a member of the Vintage Triumph Register (
www.vtr.org) there are good instructions at their website, in "members only" area.
I installed a Delco 7127-3 in my TR4, bought locally, and it wasn't difficult, but I do have some fabricating and welding skills that came in handy. There are some photos of my installation at the link below, by my signature.
The 7127-3 is a "three wire" alternator that allows using the amp gauge, if you wish. A "one wire" alternator might be a little easier in some respects, but the amp gauge won't work and they generally aren't recommended, I forget the details why, but it made sense at the time I heard it.
Hopefully this will get you started.
Hey, I think we need to put an alternator conversion article in the BCF's Knowledge Base! What with all the handy folks here on this site, I'm sure we could put together something really instructive and helpful.
