tinman58
Hi Guys
I have a TR3 with a Moss Motors Supercharger. I installed the Supercharger last July. The car ran great until I cracked the crank shaft. I rebuilt the motor with a new crank and went to the 89mm pistons. Everything else stayed the same. I have the engine running but the carb on the S/C is running REALLY RICH. All I did was remove the S/C set it on the bench then reinstalled it as it came off the old engine. I have gone thru all the obvious things and even reset the adjustments as the book says. When I start the car with the choke, gas pours out the throat of the carb. Also into the supercharger. Any thoughts
